Use this procedure to view non-EAPoL client MAC information on a port.
Use the clear-stats command to clear EAP and NEAP statistics.
Switch:1(config)#show eapol multihost non-eap-mac status ======================================================================================== Eap Oper Status ======================================================================================== PORT MAC STATE VLAN PRI Flex-UNI I-SID NON-EAP VLAN:I-SID NUM ID Enable SOURCE AUTH AUTH ---------------------------------------------------------------------------------------- 1/10 00:00:00:00:00:0e authenticated 10 2 true autoconfig radius 0:1015 ---------------------------------------------------------------------------------------- Total Number of EAP Sessions: 1
Switch(config-if)#show eapol multihost non-eap-mac status verbose ============================================================================================================= Non-Eap Oper Status Verbose ============================================================================================================= PORT MAC STATE VLAN PRI Flex-UNI I-SID NON-EAP VLAN:I-SID ACL ACEs NUM ID Enable SOURCE AUTH ------------------------------------------------------------------------------------------------------------- 1/11 00:00:00:00:01:02 authenticated N/A 0 true radius radius 0:10555 ------------------------------------------------------------------------------------------------------------- Total Number of NEAP Sessions: 1
Use the data in the following table to use the show eapol multihost non-eap-mac status command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
<1-4059> |
verbose |
Displays non-EAPoL client MAC information. |
